huge tower heatsinks in microfly/qpack?
Yep, I plan on using the Ultima-90 when it's finally available. I had to cut my case in much the same way to make it fit though.
with the qpack's design it is pretty possible to fit a tower heatsink in it. however, you're gonna have to do some trimming and the mobo tray probably won't be removable.
I have an AC64 Freezer Pro in mine. Works with both my TForce and my Abit, but the TForce required more extreme modifications.
