I got myself a zalman 9700 and it idles @ 44 & loads @ 64.
My setup is a E6400 (29A) + 965P-S3 @ 1.4v.
I was worried about the 20 degrees diff and decided to reseat the HSF (and also check if the ISH is concave), but everything looks normal. Upon reseating it, my idle was 52 initially, 50 after the zalman grease cured abit (sigh, shouldn't have touched it).
Question is, is it common to have such a huge difference between idle and load temps ?
Thanks in advance.
Thanks in advance.
