Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Hey guys,
I have had the creative s750s for about 1 year now and all of a sudden all of the right hand side channels stopped working. Any idea on how to trouble shoot this?>
1.) Check the amplifier in back of the subwoofer.
2.) Use a different speaker (one of your existing speakers that came with the unit) to rule out that it is/isnt a satellite speaker causing the problem. Do this by plugging it into the port that is giving you problems.
3.) Did you change any settings on your soundcard/interface? If so revert to default settings and test from there.
4.) If all else fails call Creative support and try to get an RMA going.
