Huge HD SATA with single partition
rob75
Hello everybody,
I need your expert suggestions.
I'm using WinXP, and I've just bought a HD SATA 320 GB.
Unfortunately, for my job pourposes, I need to to keep the whole 320GB capacity under a single volume (C:\) , without making any other partition.
I know that with old IDE Hard Disks it was generally better to sub-divide the capacity in multiple partitions (C:\, D:\, E:\ and so on...).
About SATA I don't know...
Do you think I'm going to lose speed or storage performance on my new HD?
Any comment is welcome
thanks
I would partition how ever you please, i generally like to have no data on c in case i want to reload windows, but you can always backup anyway, and ntfs can handle to 2tb easily, so that will not be a problem. SATA is just a different controler spec, not a new hard drive design, so it is really not much different then IDE, only it is much fast witht he SATA 2 spec.
hope this helps, enjoy the new drive.
i only have 1 partition on each of my drives. imo, partitions are useless. if you know how to organize your files/folders, i see no need to make partitions.
Windows install die's and you cant repair it, forcing you to format.... got to take the HD out, put it in another system to get your files off.
2 partitions - you keep all your My Docs / email files on partition D - windows install dies, reinstall windows and your files are fine.
This is the only reason i partition, i move my Docs folder / pst' files and other important directories over to the other partition, so if my windows install gets fubar;d some how, i can reinstall windows with out having to take apart my computer
There is NO performance gain from partitioning, and never has been.
I only partition my main drive if I need to run multiple Operating Systems. But I have a second drive that is for all my data and saves only programs go on the main disk.
There is performance to be gained from partitioning in certain circumstances.
If you make a small partition at the beginning of a drive and put often used files on it, the drive's heads will not have to seek very far to get to the files. I've seen this called "short-stroking" the drive.
There are more sectors per cylinder on the first part of the drive, so there are more sectors moving under the heads per revolution of the platter than sectors on the inner cylinders. This also increases performance.
which could also be achieved by a smart defragmentation algorithm, which would put these files at the beginning. What may be much more important is to localize files that are accessed together.
