Huge Case and Huge Pocket...
that looks like one of the lian-li cases
in fact exactly like it i forget the name of it but some one here on the forums has one and did a really nice job with it. If i am not mistaken i believe that the Lian-Li is actually cheaper than that one. But I have been wrong in the past.
You are correct. I think it's a Lian-Li case actually, with mods like the exposed fans, sorta like Rocketfish...except they marked up the price a 100 bucks from Lian-Li. :)
That is actually a rebadged Lian-Li PC-X2000
I don't know why Lian-Li did this. It's like buying a Mercedes with a Ford logo on it. Not saying that Ford is bad, but you know what I mean.
hmmm..well thats a lot of money for just a case... oh well ill just stick with my thermatake armor :)
I don't get the 3x 140mm fans in the front... This case SCREAMS internal triple radiator... Or hell, internal QUAD radiator, but nooooooo.
Am I the only one that thinks these cases are wayyyyyyy too big?
Depends on your intent... If you're going with a damn good SLI/CF setup, need a bunch of hard drives, and need room for a watercooling setup, I could understand it's size...
But, I personally would never buy something this large...
Or this expensive...
i know someone that has one. they're running a GTX280 + 2x 8800GTs for GPU folding. they got it just because they could afford it. all the fans are in, and he doesn't even use the side panels :S
Nice case. TjHarlow, on youtube built a rig with this case and it seemed pretty cool. Beware, though, if your planning on using Velociraptors, theres a problems with them not working properly with the stock HD cages in the case.
2Red is who you're referring to, the 599.99 is regular price and not marked up.
He has the side panel cut and modded.
