tankman1989
- Aug 21, 2009
I'm curious of the reasonings for using hubs when a switch is available. The network consists of HP servers from 2008 and HP business desktops with gigabit NIC's. There may be a few older machines running on the network that run XP but they have gigabit NIC's (these machines have older dot matrix printers running on them as local printers).
The network is setup with 6-8 servers running to a gigabit switch & switch is uplinked to 2 48 port Cisco Gigabit switches. There is a 48 port Cisco 10/100 hub as well that is plugged into one of the stitches with one cable and then one cable running from the hub to another system (reportedly a computer....)
What would be the benefit or application of using a hub attached to a switched network, especially when there is no need to have the hub in the mix (the cable plugged into the hub could be plugged into a switch as there are empty ports).
Can anyone give me any insight into why this may be set up this way? I've asked about what is connected to the hub and get very nebulous answers. It is clear that whatever is hooked up to the system is either used or monitored closely as disconnecting the wire results in its mysterious reconnection in a very short time period yet no one ever admits to reconnecting it. (they must also know to connect the hub to the switch and which cable was originally in the hub - there are no markings and all cables are identical looking).
From what I have seen it seems that reasons for this may possibly lead to the not so "legitimate" side of the IT world (well, it may be legitimate, but undisclosed we'll say).
Please any ideas about this are greatly appreicated.
