HTT limitation on A8V?
Arseface
I've got a 3000+ winchester, currently running on stock cooling. It's running in an Asus A8V motherboard.
It's a pretty decent clocker, and will do 280fsb (2520Mhz) on 1.45v without a problem (prime stable - load temps stay below 42C). However, if I increase the fsb any further I get serious instability problems. Anything over ~283 Mhz refuses to POST. The same happens if I drop my HTT multiplier down to 3x, drop the memory divider to 3:2, and drop the CPU multiplier to 8x. As such, I can only assumme that the motherboard itself is limiting the overclock...
Is there anything I can try to get around this, or am I basically 'stuck' with the maximum overclock of ~280fsb?
It's a decent overclock anyway, I know, but I just recently bought a second hand Vapochill XEII, and I was hoping to be able to get some more performance out of it, until I get a more 'multiplier friendly' chip. If there is nothing I can do to increase the fsb of the board any higher though, I'll be getting the same overclock on the vapochill as I am with the stock cooling, which seems unfortunate.
it could be that you need to increase teh volts on your RAM and your CPU Vcore. Also try a different north bridge cooler.
Memory voltage is at maximum (2.8v).
Also, increasing vcore made no difference (and neither did dropping the multiplier).
I could try a different northbridge cooler... I'm kind of leaning towards going whole-hog and buying an FX-55 to go with the vap. now though :D I'm sure the FX won't need to go as high as FSB ~280, and I can always just tune it to the right multiplier for my memory :)
