HTPC upgrade, comments needed
Ckamc
I have had this current setup for a little over 2 years and I am ready to build something miles better.
Current problems:
Playback is limited to 720p (both display and hardware limited)
Frame rate for casual gaming is lacking
Video encoding is a nightmare
Goals of build:
Reduce time spent with video encoding by 50% or better
1080p video playback and gaming with no problems (minus crysis)
Retain quiet operation, keep heat to a minimum, use of quality product to make build last as long as possible
image quality is the highest priority
Here is what I think might work, I am not on a budget but do not want to go overboard.
Silverstone CW02, 2x Noctua 92mm fans
EVGA 780i, Palit 9600GT(HDMI model)
Silverstone S12 Energy Plus 650w, E8400
4GB of Crucial Ballistix(DDR2-800), 1TB Seagate HDD
Samsung LN40A550(40"), Logitech 505w 5.1
Intel PCI-E network card, Creative X-Fi 7.1
Tuniq 120 CPU Cooler, (insert a bluray burner)
Current system (some parts may not transfer over, may be used for resale or on another build)
Antec Solo P150, 1x 92mm CoolerMaster fan
Asus A8N32-SLI Deluxe, EVGA 8600GTS
CoolerMaster 450w PSU, 3800+ Socket 939 Single Core
2GB of G.SKILL(DDR-400), 3 HDD after partition = 1.39TB (1 IDE, 2 SATA)
Viewsonic 27", Logitech 200w 2.1
Onboard Lan, Creative Audigy 2
Scythe Ninja, 8x DVD burner
One of my questions is with the video card, since video will go thru it via HDMI, should I use the sound card for audio to the 5.1 or what are my options?
Using a HTPC case for once since I will have a house now instead of a 1 bedroom apartment (so I can have a office for gaming pc build). Most likely going to use Vista. Want to very little of on-board features to ensure life expectancy along with improve every aspect including bittorrent/irc/newsgroup downloads.
My last question is, since I do not keep up with Vista, would I be fine with a dual core or would quad core provide significant improvements in overall performance? Being that the main use is HD video playback.
I hope from what I have read, 32bit Sp1 along this setup should provide great results in both video quality, cpu usage during h264 playback.... as my current system does tend to max out cpu usage during 720p bluray rips (mainly during high motion)
If you want to keep heat to a minimum, get a P35 board. Don't bother with 780i. SLI doesn't belong in an HTPC you want to be quiet and cool and those boards suck up way more power and run hotter than a P35 would.
You definitely don't need a 650W power supply. 450W would be more than enough. Corsair, Seasonic, Silverstone and Fortron-Source would be brands to check. Look for 80 plus certification.
If Image quality is your highest priority you may want to consider a Radeon HD 3850, last I heard they still had better IQ than nvidia's cards. Though if it's equalized now it doesn't really matter.
2GB of RAM would be enough, unless you're running Vista x64, though with prices the way they are currently there's no reason to not just get 4GB anyways. Since you're talking about getting Vista, I'd suggest 64-bit over 32-bit.
Why the separate PCI-Express NIC? Onboard should be fine as long as you've got Marvell PCI-Express built in. And the X-Fi... well, I think they're useless but ymmv, as they say. The desire to avoid onboard components to "ensure life expectancy" is odd. Maybe I'm not reading that correctly. As for performance, well, onboard components are just fine. Just make sure you don't have any Realtek crap on there and you'll be right as rain. No point in spending the extra cash if you don't need to.
Quad Core won't do much for your gaming and playback, although depending on your setup it could improve encoding performance.
Lastly... no tuner?
Current problems:
Save some money and:
- Get AnyDVD HD and bypass HDCP requirements on display/etc.
- Keep Mobo and upgrade to a S939 Dual Core processor (X2-4200+ / Opty 170+)
- Upgrade Video card to your 9600GT, it'll offload video HD stream and not necessitate going to a newer processor...
- Don't need Vista either, unless you plan on playing DX10 games...
Yeah I may just go with the reliable P35 board then, since I won't be doing SLI *and there is no reason to* is there anything worth wild with a X48 or just more heat?
To be honest, video encoding sucks on AMD, I want to jump to a new brand now.
SP1 allows for 32bit to read up to 4GB of ram, and I run a lot of GUI moders along with other apps in the background and found a great advantage on my current XP based system when I went from 1GB to 2GB. But does 32 offer multiple core support? or is that 64bit only?
Vista I mainly want the improved image quality and additional DXVA support provided by DX10.
I used to have a regular PCI network card but when my brother's onboard lan died I had to give it up, it did provide better performance overall, most notice-able via bittorrent (320kb onboard to 540kb pci averages)
I notice a audio quality difference (mainly improvement) with upgraded sound cards connected to a good set of speakers, I did have one before (X-fi) but after a power outage it some how died. Thus it was replaced by a cheaper model that had more linux support... but its not as sharp in audio quality (and I dont run ubuntu anymore)
I should probably get a UPS since all these surge protectors have failed me and I been thru 7 different ones. 650w PSU is mainly to have a good overhead for additional future storage (especially with bluray rips being anywhere from 4.3gb to 12gb)
I am still looking into tuner cards, but with direct tv as my provider I am not sure what I can do.
Recent reviews between the 3000 VS 9 Series shows they are both about neck and neck... since I have always been a Nvidia fan I plan to stick with the brand. There are a few cards coming out within the next couple of months so I choice may chance but HDMI is a must as DVI to HDMI isn't always a winner depending on the card and tv.
There is nothing worthwhile in the X48 chipset, IMO, especially in an HTPC setup. If you don't want P35, you could always wait for P45, but the high-end chipsets would serve no additional purpose at all.
A 32-bit OS will support multiple cores, yes. I wasn't aware that Vista SP1 allowed 32-bit Vista to make good use of more than 3GB of RAM. I still don't understand why you wouldn't want to run 64-bit if you're moving to a new OS.
You may want to consider speakers with a digital input. This would eliminate analog audio quality issues as digital output from a good onboard audio codec (Via, Sigmatel, IDT, Analog Devices) bypasses the analog part entirely and thus your speakers / receiver would handle the DAC.
From reading your post, it sounds like you're talking less about an "HTPC" and more about a computer connected to a TV. I don't think the potentially slightly faster torrents is worth the cost or space taken up by an add-in network card, but that's just me. You'd have to do some really solid throughput testing to be sure there is a difference, and if you check recent motherboard reviews that cover onboard peripheral performance you'll find that many onboard networking solutions are more than sufficient.
According to Tech Report's latest GPU article (Diamond 1GB Radeon 3870), a Core 2 Extreme X6800 - that's 65nm, so more power use than an e8400 - on an X38 motherboard with 4GB of RAM, a 320GB hard drive and a GeForce 9600GT draws a little under 200W at load. You could add 4 more hard drives to that and not even hit 250W. That same system with a 9800GTX was recorded drawing under 260W at full load.
You simply do not need a 650W PSU in an HTPC... or for that matter, in just about any single-GPU system (I suppose a 2900XT, or some other equally power-hungry video card, would make use of it). I suspect that even a good, quality 450W PSU would be more than enough.
If you want to buy one, go ahead, but a lower-rated power supply could allow for better efficiency and less heat generated by the PSU. You may want to read through a few of the recent power supply reviews at Silent PC Review if you still think you'll need such a power supply.
Thanks for knocking some more sense into me, as you can tell I am a bit stubborn.
DDR3 prices are a bit crazy as well, maybe I can find a good 35/38 board with a reasonable price, DDR2, and 8 SATA connectors.
Probably knock down how much in my PSU as well.
My test/results are with a older socket/motherboard as well... I should probably not compare old socket a to the new stuff.
You did bring up something that I have no real idea where to look... and that is Digital input speaker system.
Something thats 500W combined rms for a 5.1 and doesn't break the bank if anyone happens to know of something. Logitech 505w 5.1 has a Digital coaxial and optical... is this enough or would I have to look into something else? Looks like I may need to look into a different sound card as creative sucks up on vista.
Because, well.... most the sites I look at list the usual analog stuff. Not entirely interested in having a receiver unit like my parents have... I think the stuff available in the pc market for audio does quite well.
Found a TV Tuner now that supports HD, too bad 1080i is the limit for most of them but 720p tv rips isn't entirely bad either.
Well, that depends on what you like. If you've been using PC speaker sets, have been happy with them and don't want a receiver-style setup, then yeah, a set like those Logitechs with digital inputs would be what you're after.
If you wanted just stereo sound there would be other options, such as powered studio monitors (some of these have digital inputs) from brands like Edirol, Roland, M-Audio, etc.
I'm actually using a pair of Edirol MA-15D monitors with my current PC, paired with a Toshiba 32RV530U 32" 1080p LCD TV as my monitor, and it's a fantastic setup. I haven't found myself missing surround sound at all when using this system.
I have an HTPC in my 'home theatre' setup, though, and that's connected to a bigger DLP and a receiver for digital audio output. I tried using the analog connections (the motherboard has an older Realtek codec and doesn't support Dolby Digital Live or DTS Connect) to get surround sound for all sources and couldn't deal with the crap quality of audio. Over a digital connection it sounds great, though. The receiver does a pretty decent job of expanding stereo sources to all my speakers and AC3 passthrough works when I need it.
Anyways, you could use the onboard audio's digital output and thus have the speaker set do the digital/analog conversion, this way you won't have to deal with potentially lower quality audio using the analog outputs on a motherboard. For some solutions they are fine (Analog Devices, in my experience, provides pretty decent analog output) and for others (Realtek always comes to mind when I think of junky analog audio quality) you'd definitely want to bypass it and use the digital output.
If you're still thinking of getting an add-in sound card, I'd recommend checking out Asus' Xonar line, cards from Auzentech (except the X-Fi Prelude) or just about any card using C-Media's Oxygen HD chip, such as the HT Omega Claro or Bluegears b-Enspirer. A lot of those cards will have really good analog output thanks to the higher quality DACs they use.
As for the TV tuner, well, no one is broadcasting in 1080p, so yeah, you won't be recording in 1080p. You mentioned you have DirecTV - your best bet for recording from your satellite STB is going to be an S-Video connection to the tuner card and that can't carry an HD signal. Of course, you could always connect an antenna to the tuner card and see which digital broadcast channels you can pick up; you may be in an area where you can get the HD broadcasts over ATSC for the networks.
Hauppauge has a thing coming out soon, the HD-PVR (the website says shipping on May 1 so it may already be available in some places) that will have component inputs (yes, inputs) and can thus record HD streams from cable and satellite STBs that have component out.
I expect recordings from that device would take up less space than a straight dump of the ATSC broadcast, given that it has hardware h264 encoding built-in (recording OTA ATSC just dumps the broadcast MPEG2 stream to your hard drive and is generally about 9GB/hr) so it may be something to consider if you plan on recording a lot of shows, and is currently the only option if you want to capture HD from your satellite box.
Thanks for all the comments everyone, I believe I have a good setup now and will look forward to new line up of TV tuner cards.
Goals of build:
1.) nothing will serve you better than a quad core here if this is important to you i would grab a q6600 they are extremely cheap at the moment
2.) dependant on which games i would be looking at the 9*** series here
3.) go with 3rd party coolers
4.) dury is out here i think image quality is now just about equal accross the brands
I am having a hard time finding any recent quadcore vs dual core in terms of h264 playback...
I know how much of a difference it makes with encoding.. but to have come so far from where I am at with this amd to a E8400 I think a bit of overclocking will do the trick
Yeah I am going aftermarket cooler for the GPU, but as I stated earlier my main want is direct output, no adapter as that can be a problem ... not looking into a 9800GX2 or GTX since that way too much and hopes that the new 9900's or some revisions of the 9800/9600's will come hdmi direct... even tho the card I have listed does... it nice to have alternatives
I wont ever use a stock cpu cooler... still debating tuniq and notuca and scythe
Just wondering why not? for HTPC there is no overclocking...so is it because of noise considerations?
I'm assumng (based on my own experience) that it's because the stock coolers are piles of crap; too noise and don't cool well enough in an airflow starved (like a typical HTPC case) case.
What I'm wondering is why anyone has to even ask why the stock coolers suck in an HTPC. :rolleyes: :rolleyes:
For confirmation. I'm just getting into HTPC setups. My desktop is designed around silence but not specifically HTPC, but it's on a stock cooler for now. It whines like anything but it's inaudible if you're not in front of it.
Anyway, back on topic. Zalman's make great, silent, cooling.
ckamc, if you want a native HDMI output that will pass audio you might want to look into a Radeon HD 3650 or 3850. The adapters they include allow them to route audio over HDMI and you don't need to connect your sound source to the video card. I believe all of the current nvidia cards with HDMI outputs require the sound card's digital output to be connected somehow to be able to pass along audio.
Also, as far as playback is concerned, the hardware acceleration in the newer cards makes a huge difference. An E8400 would be way overkill for playback.
See here for info:
http://techreport.com/articles.x/14261/9
As you can see, a 2.5GHz Athlon X2 paired with a Radeon HD 3450 has very low CPU utilization during playback. I remember seeing another article somewhere in which some testing was done to see how low-end of a processor could be used to have smooth HD playback with these newer cards and it was something like a 1.9GHz Athlon X2 or 1.8GHz dual-core Pentium (the core-based ones, obviously, not netburst). I'll see if I can find the link.
(edit)
Silent PC Review has tests with an underclocked 4850e on 780G; they show stutter-free playback at 1080p with the processor at just 1.5GHz (their WVC-1 clip is 720p but apparently a much more demanding implementation of standard VC-1, the rest are in 1080p):
http://www.silentpcreview.com/article807-page8.html
Not sure where I read about the Intel setups, though.
This HTPC will also play games
Yeah I read how to hook up the audio to the hdmi
Correct, a stock cooler is rather noisy and with a proper heatsink and fan combo it will not only keep it cooler than stock, but quiet
I know this will sound like treason here...but....
I would recommend just going with a pre-built from VM, Dell or HP. I have a dell with an ATI card (HD 2600xtx super xfire 1337 pwnage edition on fire) I believe a C2D qx6600 3 gb or ram and so on. The machine cost about a $1k, I added on a few cable card tuners. It's silent, stable, came with a remote and some a little leather binder to keep all your useless CDs.
I have had it now fow about 5 months or so and let me tell you...it's awesome. I look back on my custom HTPC days and wonder what the hell I was thinking. Leave the HTPCs to the SIs and tweak the hell out of your gaming machine. There is nothing worse than having to troubleshoot a custom built machine when you are supposed to be recording your favorite show.
You said in your first post that your display is limited to 720p; if this is the case then the highest res you'd be gaming in is 1280x720. A 4450e and an HD3850 is plenty at that resolution.
Just wanted to point that out. If you're set on having that C2D in the system, go for it. But for a display limited to 1280x720 it's a lot of extra horsepower.
