HTPC Network Hub
Figured I would make a log to motivate me to work.
Here goes.
Case overview:
Front
HD Tray to be modified
The plan:2 60mm fans on the sides blowing through a server copper heat sink as well as the memory towards the hard drive via plastic ducting made from plastic.
Cover up where the ethernet ports were with mesh.
HD Under DVD drive
I need to figure out how to modify this LED circuit so I can hook the LED's and the switch into the motherboard, any ideas?
LED Circuit
