HTPC Keyboard suggestions
bosstone74
I would like a small RF keyboard with a mouse integrated into it for my HTPC, anyone have some suggestions?
Interesting, however I was looking for something a bit larger that I could put in my lap and type, I am thinking without the 10 keys, and RF.
If you are not looking to spend much then this one is pretty good. I have had this for over 6 months with no issues. The Joystick mouse works great and I have had no reception issues, but I am only about 10 feet from the pc. It not currently available at newegg, but I think frys carriers it if you have one near you.
http://www.newegg.com/Product/Product.aspx?Item=N82E16823110017
I only have the remote that comes with this one, but based on how well the remote works I would assume that the keyboard would be pretty nice too.
http://www.newegg.com/Product/Product.aspx?Item=N82E16823172015
Well, I'm using the Vidabox as well as a friend who is also a member here, and we really don't have many complaints. Mine has been pretty solid since I built my theater. I've only had to change the batteries once in it, and they're due for another change soon. When the battery gets weak, it sort of loses signal for a split second, but that's to be expected. The control it gives you is just like a trackball. It's real easy to use and type on.
