Jul 25, 2008 #1 I import [H]ard|Gawd Joined Oct 14, 2002 Messages 1,467 need to put together a basic htpc. needs hdmi out, optical audio out. nothing fancy. any reccomendations on the mobo/cpu combo that would work best?
Jul 25, 2008 #2 w1retap [H]F Junkie 2FA Joined Jul 17, 2006 Messages 14,608 Budget for everything? Are you building from the ground up?
Jul 25, 2008 #3 D Deleted member 89018 Guest An AMD 780G motherboard and a low power Athlon X2 are excellent for HTPC use. You may want to check out this guide: http://arstechnica.com/guides/buyer/guide-200804.ars
Jul 25, 2008 #4 C cyron1 Limp Gawd Joined Jul 30, 2006 Messages 193 if you go with an AMD system, try this board http://www.newegg.com/Product/Product.aspx?Item=N82E16813128090
Jul 25, 2008 #5 w1retap [H]F Junkie 2FA Joined Jul 17, 2006 Messages 14,608 http://hardforum.com/showthread.php?t=1260174
