- Nov 14, 2004
So, I'm working on the newest incarnation of my main HTPC (current one is in a Wesena ITX7-2), and am trying to decide which case size to go with (both are custom plexi deals). All measurements are internal volumes (or use frictionless planes of zero thickness plexi... lol
Both systems will have the baseline of:
- i3-2100 processor from the older system
- 128GB Runcore T50 mSATA SSD
Option 1 (The Blade):
- Thin mini ITX
- Offset intel cooler w/ scroll fan
- 2x8GB ddr3 sodimms
- 1x 3TB Western Digital Green (or 4TB Hitachi)
- Custom black plexi case w/ the mobo in the middle, the cooler offset to one side, and the 3.5" drive mounted to the bottom of the case on the other side. Overall dimensions (swag) looking like 375mm(W) by 185mm(D) by 30mm(H).
Option 2 (The Mallet)
- mini ITX
- Gelid Slim Silence iPlus cooler
- 2x4GB ddr3 (from old machine)
- 2x 3TB Western Digital Green drives
- Custom black plexi case w/ the mobo mounted a little bit higher than normal (traditional standoffs are 6mm, these would be 18mm), and 2x 3.5" drives mounted on top of each other to the side of the motherboard. Overall dimensions (again, a swag) looking like 285mm(W) by 185mm(D) by 55mm(H).
Option 3 (The Safety)
- Basically the same as Option 2, but with one HDD, traditional standoff sizes, and a guesstimated case height of ~43mm. This would give a bit more space for the HDD to passively cool.
Considerations:
- Currently, my HTPC is approaching max capacity (3TB currently) with about 5% free. I could upgrade to a 4TB drive, but this would cost just about the same as redoing the whole system
- I would like the smallest form factor possible; Option 1 would be awesome if that intel cooler didn't add 90mm to the width of the case and a potentially loud-ass fan.
- Are there any cases out there that basically look like a M350 with a 3.5" drive next to them? I guess I could just go with a M350 mod with an external 3.5" drive (USB3) but that seems to go against the idea of this system.
- Wireless HD streaming is out of the question (as is running cat6) due to home construction materials / terms of lease.
Enough of my ramblings, hopefully this promotes some good discussion about the next step down from big mitx cases
- Thin mini ITX
- mini ITX
Considerations:
