HTPC Editorial @ [H] Consumer
  • Thread starter Deleted member 119758
  • Start date
I miss the old [H].
A lot of the points and contentions you make are nearly ridicules.
The 8000HD also features an external SATA (eSATA) port for adding an additional hard drive (this port is sometimes deactivated, however).
These STB/PVR combos often carry one or more USB ports, although generally they are not enabled. Once they are, however, the potential capabilities of the device begin to open up even further. As the 8000HD Home Entertainment Server’s name suggests, the potential to store and view other entertainment media, such as music and photos, might not be too far away. Taking all the features together, these STB/PVR combos begin to look a lot like stripped-down HTPCs.
Hardly. As you said, STBs have had USB (and Firewire) on them for a while now; his is nothing new. The problem is that they're nearly all disabled and if enabled they can be used only for technician purposes. I hope you don't hold your breath waiting for someone to enable these ports for you cause if someone was going to get anything usefully from the USB ports on an STB it would have happened by now.
Hopefully more STBs will have an enabled and usable eSATA port but I'm not going to count on it. It took them forever to do this with Firewire and that was suppose to be a handy way to connect your STB digitally to your TV or PC (mandated by the FCC no less).
With interactive programming guides, dual HD tuner capabilities, and a simple user interface, even the most extreme technophobe can get the hang of it with minimal difficulty.
I can believe you just said an STB's UI was "simple" and ease to use cause there are several posts already here that point out how terrible they are. I often wonder if they get people who love to inflict pain on others to design their UIs... that or stupid monkeys. I refuse to use the TV at my Aunt and Uncle's place for this reason, they have Sat and UI is just god awful.
Honestly, if you think an app like SageTV, Beyond TV or MCE is hard to use them I think it would be best to just step away from the TV. Clearly, operating a remote is far too difficult for you.
On Digital Streamers, you render your whole argument moot by stating:
Often, manufacturers design them to take advantage of special features available through technologies such as Intel’s Viiv and Microsoft’s Media Center OS.
So you do need an HTPC system in order to take advantage of these special features, huh?
Anyways Streamers are nowhere near what an HTPC is and they're certainly no replacement for one. For one thing you have to deal with the limited video and music formats, the best example of this is the 360. The 360 is pretty much the only streamer I would consider simple because it doesn't suffer from the other problems that plague your average digital streamer (like frequent crashes) but you'd think that with a three core CPU and a powerful GPU you'd be able to watch those Divx video files that you have on your PC or the DVDs you've already (as mentioned earlier in the article) converted to Divx. Whats that? You can't?! But I thought these extender devices where suppose to be able to replace an HTPC, I would have thought that this would include being able to playback one of the most common video codecs out there. :rolleyes:
Hell, they can't even play back a ripped DVD on a media server.
Secondly, have you ever used one of these devices? Most of their UIs are reminiscent of the one used for most STBs. Terrible.
And I'm not even going to go into how noisy a damn 360 is. Ugh.
The only thing you've gotten right is the situation involving DRM but the way you phrase it makes it sound like you don't really understand it by the examples you state. DRM will choke the HTPC and stands as the only thing that could possibly kill it; this is already happening with HD content on the PC.
Regardless I have to say that this article wasn't as bad as other hardware site's articles on HTPCs... which isn't saying much cause they're all usually terrible. I just wish there was someone at these sites writing these kinds of articles that knew WTH they were talking about. Until then I'll go to a real HTPC site for thought provoking editorial content.
have both, an HTPC and a HD PVR. For ease of use, it's the PVR, no question, but for sharing media, (obviously) it's the PC.
This is the way I go. The PVR with Dish stores about 40 hours HD or 300 hours SD which is typically enough. The HTPC has access to several gigs of music and about 750 movies, converted from MPG2 to MPG4 at the highest quality settings so they look good enough on a 50" plasma and consume 1/3 the space. Impatiently waiting for HD optical disks to start to make some sense.
I'll admit I haven't read all the comments here....but regarding HDTV.
Using an HTPC as a personal video recorder (PVR) also lost much of its allure. Once consumers had their first taste of HD programming, standard definition TV looked appalling by comparison. Users could install expensive HDTV tuner cards, but the massive storage requirements HD demands would quickly clog even the largest of hard drives. Furthermore, users that had to go through a set-top box (STB) to receive HD or even SD programming found themselves limited to viewing and recording only one program at a time.
I have had and ditched HD service twice now because the difference in quality is not worth the price. So HD is a nonstarter....and my HTPC with it's ability to almost endlessly increase storage works better for me especially with my SD tuners.
IMHO the felxability of the HTPC cannot be rivaled in an embedded box.
The 360 as an iptv client (recently demoed) and as a MC extender compliment the HTPC, but do not replace it.
The ability to expand storage on demand, update for codecs as needed and generally fully customioze the experience make the HTPC the ultimate solution for the media enthusiast.
As to ease of use: I have TiVO, three ReplayTVs and a Vista Media Center rig and a Comcast PVR running MSFT software.
The Comcast box is going back to Comcast. 120GB for HD? Is that a joke?
The Replays are on a shelf.
The TiVO is in a box.
The Vista Media Center rig with two NTSC and two HD tuners is the one I use. My music is on a server, my videos are on the server. The box has 1TB of local storage for recordings. It is rock solid reliable now that ATI updated their drivers. The HTPC and video comunity providing support with things like FFDSHOW, Halii and DVRMSToolbox just add to the robustness of the solution.
In my mind nothing beats a well thought out and configured Media Center machine.
PVRs from the cable companies? Sure they have lots of ports on the back: with the exception of the 1394 port they are all disabled. esata and USB do nothing and 1394 is good only for video.
I’m sorry, but the article is probably the worst “argumentative” article I’ve read from a professional group. The title of the article should be “HTPC’s are still to much work for the limited PC knowledge of the masses”.
As even simple point of faulty logic, it was said HD-DVD is so big compared to hard-drives and you can’t possibly store it. What was the standard HDD size when DVD’s came out? My guess is the author doesn’t know.
HTPC’s are keeping abreast of technology, it s the population of the world that isn’t. I guess people just like the “plug in and use” bandwagon regardless of the limitation.
Sorry, negative Digg.
Did you actually have an HD display? On a 92" projector screen the difference is night and day. Seriously. Watching, say, Battelstar Galactica in 5.1 audio on Universal HD is amazing comapred to the stereo nodef SciFi version.
i dunno.. i remember when i ripped a CD using WMA, i couldn't play it on my mom's laptop. is said something about a license or something.
RTFM dude. There's a checkbox on older version of Windows Media Player that defualted to applying DRM to ripped CDs. Either udpate WMP or uncheck the box.
I have untold gigs of losslessly ripped WMA files sitting on a file server that is shared across my network.
You know I never thought of that....damn my 35 year old tube tv's and their UHF/VHF inputs. Of course I have HDTV's.
Most of the HTPC oriented articles from pro-level sites are nearly complete crap from my experience. The only time I've ever read a good review of HTPC hardware as been from an HTPC oriented site.
The best example of this is Anandtech's HTPC articles, they're considered a joke to anyone that knows anything about TV tuners and such. It looks like [H] might be going down the same road too if they're last two articles are anything to judge by (the one on HDTV and this one). :(
This was surprising because AT actually has the best all-around reviews IMHO, however I do agree.
I personally think the HW review community has really grown stagnant as of late. Most of the reviews/articles/OpEd are really lacking and I hope that something happens soon to change that.
I personally would like to see a site structured where the site maintains the perfect virtual, digital-home. This VDH would have the following components:
Ultimate Gaming Machine
Workstation/Productivity
HTPC
Laptop
Network Storage
Router
General Purpose Machine
and so on.
Basically, when reviews are done, a determination would be made as to whether or not the product in question is good enough to replace or supplement the current setup. People could see a history of the changes made to the equipment and then read the review as to why the current hardware/software/periph was chosen.
I just get the sense that most of us who have been upgrading computers since the apple IIc are tired of minor interative updates. Focus should be shifted to the larger picture of our digital lives.
Just a thought.....
