Matthew Kane
- Dec 1, 2007
Sup all, I'm after some helpful suggestions from all you [H] members on a HTPC build for a family relative based on and for the following:
* $350-400 absolute max budget for a HTPC case (best if no towers), mobo/cpu/ram and PSU
* It will be used for streaming HD movies as well as casual browsing.
* Case should be able to fit medium sized HSF's as well as a full size graphics card (no low profiles) and be able to fit 2 hard drives with optional possibility of ssd/laptop hard-drive mounts. (Optional for the case: remote control, LCD display)
* Hdd's, graphic cards and optical drive are provided so they are not counted into the budget.
* Preferably quad core based, AMD welcome but best staying with Intel (bit pricier).
* Parts should be available to me down under Australia.
Cheers
Cheers
