mattchapman
- Dec 30, 2005
I'm planning a low power, mid-range HTPC. It will be used primarily for 1080p playback (h264/bluray) and perhaps some light gaming. Most of my files will be obtained from an ethernet cable from my storage PC in another room so no need for tons of hard drives.
My AV Receiver is Onkyo TX-Sr604 and my TV is Samsung LN-S4696.
I've overwhelmed with choices so need some help!
You'll notice I've opted for an AMD build...this is because I read Core i3 does not play some movies correctly and skips. Not sure it will be a big issue for me but it swayed me to AMD (which is also cheaper).
Here's what I have so far in terms of possible choices:
CASE (I want something low profile)
Silverstone ML03 black $60
CPU (low power is preferable to keep heat down)
AMD Athlon II X2 235e 2.7GHz 45W $80
AMD Athlon II X2 250 3.0GHz 65W $61
CPU FAN (not sure I need this but what the hell)
Shuriken Low Profile $45
MOBO (I heard 890GX is the best IGP but 880 probably also fine)
GIGABYTE GA-880GMA-UD2H $100
ASUS M4A88TD-M EVO/USB3 $100
ASRock 880GMH/USB3 $100
MSI 880GM-E43 $80
MSI 890GXM-G65 $120
ASRock 890GM PRO3 $95
MEMORY
4GB DDR3 1333MHz $dunno
PSU (need to be quiet)
Antec Earthwatts 380W (140mm) $40
Seasonic S12 II 430W (100mm) $65
SILVERSTONE ST45SF 450W $80
FANS
Noctua NF-R8 80mm Fan
GPU
Radeon 5450 - optional upgrade later
TUNER
Hauppage HVR 2250 - optional upgrade later
HARD DRIVE
Samsung 2TB F4
OPTICAL
Samsung SH-B123L $90
Thanks
MSI 880GM-E43 $80
MSI 890GXM-G65 $120
MEMORY
FANS
GPU
TUNER
HARD DRIVE
Samsung 2TB F4
OPTICAL
Thanks
