HTPC / Video Re-compressing / Usenet / Archiving / Home-server functions
The PC is currently hardwired to network.
I would prefer to stay under or around $500, before a TV tuner card and please recommend one for PVR functions.
3) Where do you live?
Northern Alexandria (comcastic)
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
Power Supply - Must fit the case (current PSU is loud and probably about to die, MPT-301)
Video Card
Motherboard
CPU
CPU Heatsink/Fan (if the retail one isn't good enough)
Audio (if the motherboard isn't good enough)
Hard Drive 2 TB
Cooler Master Case CAV-T04-UWA
Live X Gamer Card - CT4760
Logitech Z-5500
Lenovo Mini Wireless Keyboard N5901
DVD Drive RW
6) Will you be overclocking?
No
Right now I have a 32" tube TV, plan to upgrade someday to a 1080i/p (whichever better) HD TV
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
HDMI for future use, unless video card can do it.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? 32bit or 64bit?
Windows 7 Home Premium
I'm not sure if I should go AMD or Intel on this build, I would like to keep it low noise fan cooled only. If the case doesn't work out I would like to go to smaller one if it can keep the full functions needed.
Video Card
Motherboard
CPU
Hard Drive 2 TB
Logitech Z-5500
DVD Drive RW
No
ASAP
