HTPC and WHS in one?
SpeedyVV
I was thinking of building a WHS.
Currently I also use a laptop (with dead lcd) as my HTPC.
Can I just buy a mobo with integrated video, or even buy a cheap video card and run a movies out of the WHS box?
BTW, I am using the term HTPC loosely. I basically play a video file every now and then, some music, or play a DVD of the HTPC onto my connected LCD TV. (1080i or 720p)
Thanks
ummm....well yea you could unless you want like Media Center functions like MyMovies, or netflix instant view, then you will have to come up with a different solution.
If you want to build a box that has WHS on it and just play movies music etc, in like Windows Media Player or iTunes then you can just run WHS no problem.
Eitherway you go get a GIGABYTE GA-MA78GM-S2H AM2+/AM2 AMD 780G HDMI Micro ATX AMD Motherboard
and a AMD 4050e
Plenty of power for WHS and to play 1080p content...no need for a pcie video card. I just built a HTPC with those components and it does anything I throw at it except running MacOSX didnt like that...but runs Vista Ultimate like a champ.
I have that on my TV stack and just have a network share to my WHS box. Have fun d00d.
