HTPC 1080p and SLI
TxRydawg
Im having "blue" dots/artifacts on black surfaces when gaming at 1080p resolution. I'm not certain if it's an issue with my video cards ( 2 x 8800gt in sli) or the television Vizio 47 lcd 1080p (dvi-hdmi dongle). When I lower the resolution it doesn't do this. Has anyone else had any experience with SLI and HD 1080p resolutions? If I'm not being specific enough let me know what additional info would be useful, thanks.
try a different(shorter, if yours is long) hdmi cable & dongle if possible.
Try a new cable; possible that the cards are defunct (memory on them?) so RMA might be possible.
got a better quality cable as well as a better dvi-hdmi connector and all is well 1080p in WOW and COD4 woot! Thank you for your input as I do appreciate it :cool:
Well glad you got it resolved, I use to 8800GT's in SLI hooked up to a Aquos 32LCGP3U and I use a gold plated DVI-HDMI cable thats only 3 ft long. I have had no issues with this set up so far.
