Hello,
I'm having some issues with the following forms & inputs: http://pastebin.com/5R6kCpTF
I'm not sure the best way to do this... I'm trying to have thumbnails that will click/submit but then below that will be some other type of forms..
The first issue is, the first set of inputs are not working in IE because I'm using type="image" and the value is not sent correctly (it works fine in Chrome/Firefox though)
The second issue is with the input at line 32. It will work, but then the value from the first group of input is never sent along with the new data
Also, any good resources to help me become pro with this type of forms/inputs?
thanks!!!
thanks!!!
