HT Omega Claro Plus Setup
wolf549
Hello there [H] forum users! I have a couple of questions if anyone has any experience working with the HT Omega drivers and user interface. I've had this card for about two years now and it sounds wonderful paired with my Sennheiser HD595 headphones. I've fiddled around with their audio options, however I've never felt like I got the true value out of these drivers so I've decided to come here.
I do a lot of gaming on my PC as well as listen to music and watch movies and I'd like to know the optimal settings for these different activities. I recently contacted the HT Omega Customer support to ask what they recommend and they gave me a new set of drivers that have this "EX Xear 3D" option that I notice no difference when I turn on or off in the panel. For System Input they suggested I used 2 CH because I use headphones instead of the 8CH which I had been using before. I'll post several pictures of the UI to guide people or who can help explain the different features.
The 1st image shows what I currently am using.
http://imgur.com/YP7ZOcR
This second image shows that the DSP mode is diabled and the settings that are available for me to use.
http://imgur.com/N3kUJUI
This third image shows what system input settings are available to me and the window on the right changes when I have DSP Mode enabled.
http://imgur.com/AjPpyi9
Thank you all for your help in advance.
EDIT: I guess I should clarify that for PC Gaming I'm looking for good positional audio and I want to be able to hear more subtle effects like footsteps (namely in BF4 and CS:GO) better.
