HSF for sg01-e help, nt06?
Anybody know if the NT06 works on AM2 sockets, I can't find anything that confirms that it does... Are there any other cheaper options?
Thanks
-Matt
yes it definately should. The hsf bracket is the same for 754, 939, and am2. The nt06 is really the best cooler for that case if you have a psu with a 120mm fan on the bottom.
