HSF for Lian Li Q08
I have a Lian Li Q08 and am a bit disappointed in the acoustics of my system. I plan on buying a few undervolting cables for the top and front fans, The stock CPU fan on my i3 is pretty annoying on it's own, and lowering the system fan speeds it will probably stand out even more. I am looking for a HSF to replace the stock that is quiet and cools well. I'm mostly worried about size constraints, and motherboard layouts and clearance, since they can block the RAM slots or have other clearance issues, especially on an ITX board. The PSU on the Q08 blocks a lot of space above the CPU. SPCR used a Scythe Samurai ZZ in their Q08 review, but would like other suggestions. I don't know if it matters, but here's how my mobo looks like. Are ITX all basically spaced the same?
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128721&cm_re=h97n-_-13-128-721-_-Product
How about an AIO? There have been several versions on the web featuring a H90 in the front (though no HDD Cage) or a H50 in the front.
Otherwise I'd suggest you a Scythe Shuriken (solid choice, reliable and quiet) or a Noctua NH-L9i. Those low-height HSF are usually all built to fit all mobos (layouts may differ indeed) but you can check on most manufacturer's websites if you're unsure.
