You may have noticed this topic in another thread, but I've got a focused question now, so I'm creating a new thread.
I'm looking for a HSF for an overclock of a XP-M 2400+ (Barton).
I've looked at the Zalman 7000A, Swiftech MCX462+, and Vantec Aeroflow2. There are some concerns that the DFI Infinity board has resistor/capacitor crowding by the HS mounting holes, which definitely complicate the Zalman and other bolt mounted boards . I don't really feel like cutting the HSF unit up to mount it, either.
So, in short, which HSF is a good choice for a XP-M running at 2.3-2.4 ghz in a DFI Infinity? If possible, I'd like the unit to come with fan, under 45$. Noise isn't a huge problem, as long as the police don't get called.
p.s. I'm thinkin Antec 1080AMG for a case, so there will be plenty of room.
