Jul 20, 2004 #1 M mjl Limp Gawd Joined Jun 9, 2004 Messages 157 will the zalman 7000cu fit into a EPoX EP-8KDA3+ nForce3 250Gb mobo?? i also have the cooler master pratorian case..... thanks
Jul 20, 2004 #2 R Rich9710 Limp Gawd Joined Jun 18, 2004 Messages 157 It should fit in easily. The only concern I might have is if you are using really tall RAM, like the Corsair PRO series. That might interfere. But I doubt it, since the Zalman's clearance is excellent. Go for it.
