HP’s Prototype Machine Boasts 160TB of System Memory
Megalith
24-bit/48kHz
Hewlett Packard Enterprise’s got a fancy new machine that can store over 6,000 Blu-rays in memory. The so-called world’s largest single-memory computer represents the company’s change of focus from processor-driven to memory-driven technology for working with big data. In the future, HPE believes the architecture can be scaled from terabytes to exabytes, with 4,096 yottabytes mentioned as a hypothetical amount.
...HPE believes that when it comes to analytics, throwing more and more processors at vast sets of data is not the answer. Rather, a different approach to computing is needed, built around memory rather than the CPU – thus eliminating the relatively clunky and inefficient manner that the processor, memory and storage interact in today’s machines. HPE’s prototype computer boasts some 160TB of memory spread across 40 physical nodes, and uses an optimized Linux-based operating system driven by a ThunderX2 dual-socket ARMv8-A workload-optimized processor.
that is sure a lot of mem, but is the cost worth it compared to just using ssds?
Obligatory...
There is a fundamental difference in the computing solution. Any computing solution is limited by how much data can be held in memory, and conversely, how much memory can be addressed as a whole. If you use a conventional solution then you can only work with so much data at a time so for big data you have to divide the work up into jobs. But the whole point of big data is to work within massive data sets. This approach allows for truly massive data sets and it allows you to work with multiple massive data sets to draw correlations between them.
W.O.P.R. comes to mind.
"Would you like to play a game?"
Random accessed porn has never been available in all of history. Salute to you, HP.
I don't even have a server (yet) with that much disk space :eek:
Most memory I have is use for any single virtual server is 40GB.
It's our main SQL server, and that's enough memory to hold the most used parts of our database, so I'm more limited by CPU than I/O.
