OK So I now have three of these in Eyefinity display mode...
Pix plz
Was that from Cost Central? I ordered mine Tuesday night and waiting for tracking.I ordered mine last Sunday, and I barely got a tracking number. Won't be here until next Wed....WTF. Sigh.
so if you feed it 1080p video, it can't display it as 1920x1080??? That's seems like a dumb design...
Looks like Buy.com has it for $395 with free shipping and 4-7% Bing cash back.
http://www.buy.com/prod/zr24w-24in-s-ips-lcd-mon-sby/q/loc/101/214928474.html
Can someone please take a look at this and make sure I'm not buying the wrong thing? Just want to make sure before I pull the trigger.
Currently that appears to be the case...there's no way to turn on `Fill to Aspect Ratio' for 1080p. The only option you get is `Overscan,' along with `Fill to Screen.'
I sent an e-mail to HP tech support this morning about it and all I got back was a link to the User's Manual. =( I haven't heard back from my reply where I specifically asked about 1080p, and why `Fill to Aspect' doesn't seem to be supported. He seemed to be stressing that the `Factory Preset Modes' listed in the User's Manual were the only supported modes for the monitor though... Unfortunately when I was going through the modes again I noticed that I completely missed noticing that 1280x720 is NOT listed in the factory preset modes for the ZR24w! =( I must have just glossed over it, since there are a few 1280x modes listed (1280x960 and 1280x1024) and it is listed for the ZR22w.
ok guys i've seen enough of the ps3/xbox questions so i will have pics for you in a moment... it is FINE lookin
http://sadfish.net/zr24w/playstation 1920x1080 x1.jpg
http://sadfish.net/zr24w/playstation 1920x1080 x2.JPG
if you want to see other pics then http://sadfish.net/zr24w
everything i've taken pics of is without touching anything in the OSD except "information" all i used to connect to the PS3 was an HDMI cable (from time warner, nothing special) an HDMI (female) to DVI (female) adapter that i've had for around 5 years when HDMI first started hitting consumerdom.
i dont have an xbox or i'd test that for you. =( PS3 seems to work beautifully though
ffxiii 1080p
little big planet 720p
http://sadfish.net/zr24w/playstation 720p x1.JPG
http://sadfish.net/zr24w/playstation 720p x2.JPG
ffxiii 1080p
Nothing in the OSD got changed after the calibration.
Well, I don't know what's going on here. Usually games use their own gamma setting, and erase the one the software calibration has done.
Have you tried several games ? Is the calibration making a huge difference, easy to spot ?
Blackbird, you just got a bad monitor you need to get a replacement. Other then the issues have you tried comparing with your HP w2207h? You said you would let me know.
Hay guys
I take it the 720p, 1080p scaling problem only affects consoles and stuff getting put through the screen or does it also affect the PC side of the screen too when viewing Blu-Ray/HD movies in windows???
Thanks for responding.
Windows does not have this problem because the media player will show the image at it's correct resolution with black bars above/below the picture. With consoles the monitor would have to know to do this and apparently it doesn't, which sucks. Oh well, still a great monitor otherwise.
