Hi,
I'm shopping for a big monitor for a new computer build and the HP ZR24w and Dell U2410 kept popping up as ones I should consider. I'm about to pull the trigger on the HP, but I would like to know if there's another monitor I should consider instead.
I eliminated the Dell based on what I learned in the HP ZR24w thread ( http://hardforum.com/showthread.php?t=1491561&page=102 ) about wide gamut monitors and why I wouldn't want one if I'm just doing normal, non-graphic design work.
I'll use it mostly for "office work", lots of text, writing, e-mail, lots of web surfing, web development, some photo work, some video, and I'd like to start checking out some games, in that priority order. Games are definitely a very low priority. Although I'm not into color correction and calibration now, it's something I might spend more time with in a couple of years.
Sharp text is a high priority, if anything, and colors that are consistent and sharp across the screen. Backlight bleed might be annoying, but I don't think I'll have black screens that often.
I'm not very picky about monitor quality, but if you put a good one next to a bad one and point out the flaws, I'll want the good one -- unless it's too expensive. The 17" very old 4:3 backup monitor I'm using now isn't even too bad, except I can sometimes see colors around black text on white background and the white is more of a cream color even though I tried to adjust the color temperature. I actually compared this "KDS" brand monitor to a 3-year-old 17" 16:9 Viewsonic and the Viewsonic seemed worse, with red shadows around bold black text in Firefox's tab titles.
I think that being able to see the monitor from different angles isn't too important to me because I look at it straight on, but I would like uniform color across the screen.
I'm looking for a monitor that will last 10+ years and I'll use it 12-14+ hours a day, so I figure I should invest in a good one.
I've never used a monitor larger than 17", and I think I might even like one larger than 24", but I'd like to keep the price around $500 or less.
Because my work is primarily web-based, I think I'd want the images on my monitor to look as crappy as on everyone else's monitors. But just with a larger screen -- that will last a long time.
It sounds like 1920x1200 is the way to go, at least the minimum. Not x1080.
Anti-glare is a must. No glossy.
An LED monitor would be nice, but it doesn't seem like there's that much electricity cost savings and there don't seem to be too many of them right now.
I came across these monitors that seem to also kinda fit what I'm looking for:
HP Compaq LA2405wg - Might as well just get the HP ZR24w for a little bit more because it seems to be built better.
Viewsonic VG2427wm - $250, but "only" x1080. The extra 120 pixels might add up over the long-term. The reviewers on tigerdirect don't seem to be too happy with Viewsonic, and support is important to me. I'm willing to pay more for it.
SAMSUNG 2443BWT - I might as well get an IPS display for the same price.
Refurbished is okay too with the same warranty as a new monitor.
I'd like to buy the monitor locally in case there are problems with it; it'll be easier to exchange. But I haven't seen any place locally (San Francisco) that sells the HP. I've read some of the posts about issues with the HP and dead pixels, so I guess I'll just take my chances. One or two dead pixels isn't going to bother me I think. I'll probably get it very soon from tigerdirect.com with bing cashback. I just noticed the price increased $10 there.
Because I'm not that picky with monitors, should I consider something larger and/or cheaper? The overall build quality of some of the cheaper monitors concerns me, such as weak stands and therefore their lifespan, so maybe it's best that I invest in the HP for the long term.
Please let me know what you think.
Thanks!
-- Ed
Thanks!
-- Ed
