Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I just picked one of these up from Newegg, and had to kick the brightness down from default (100) - have mine on 50 right now.
This is a pro level S-IPS monitor, so don't expect the typical "overblown" look of the colors that are common with lower-end models. Most of those are bright as hell, but color reproduction is bottom of the barrel. There is a big difference between brightness and overexposed image.
The ZR22w IS CCFL backlit, though; so if yours has a lot of heavy usage; it is conceivable that the backlight tube has seen better days.
Could anyone comment on the max refresh rate you're able to get out of this monitor at its default resolution (1920x1080)? Macmall is having a sale on these, and the price is compelling enough that I'm thinking of grabbing one even though I'd prefer a 1920x1200 resolution.
The specs on HP's site say the vertical refresh can go up to 76Hz, though it seems to say it can't get that high at 1920x1080. Has anyone been able to hit 72Hz at its default?
i'll buy this screen, i heard many good things about it
but more opinions is better
if anyone here got one, and could give their feedback on it, it would be great
I just got this monitor, 'upgraded' from a Soyo Topaz S that was on its last legs. I say 'upgraded' because I went down to 1920x1080 from 1920x1200. But the HP is better built, has more input options, a proper adjustable stand, and a better screen, so its still an upgrade really. Text and images are really sharp, by virtue of cramming so many pixels in such a comparatively small space. The anti-glare coating is sparkly, but I really don't mind that at all as I prefer anti-glare to mirror. Gaming on it seems good. I don't notice any input lag. I mostly play Arkham Asylum and Darksiders nowadays on my PC, and I'm not a hardcore multiplayer.
My biggest complaints are the fact that HP says this monitor is S-IPS on its product specifications, so I thought it was 8-bit. It wasn't until I did some actual research before buying that I found out it was 6-bit e-IPS (I wound up buying the monitor anyway, so I guess this isn't really a complaint). My second is the presence of a yellowish tint on the left hand side of the screen. However, over the 2 weeks that I've had it the tint seems to have faded gradually (that, or my eyes are getting used to it, which may not be a good thing?). Its possible that proper color calibration (which I haven't done at all) would fix this problem.
One of these days I'll go back to 1920x1200 or up to 2560x1600, but I still think this was a great purchase in the interim.
I figured this might be of interest to anyone who's running this monitor:
I just upgraded my system a bit, particularly I added an EVGA GTX560Ti 448 Core that has a DisplayPort output. Using the DisplayPort input of the ZR22W I found I was able to hit a refresh rate of 70Hz, then 72Hz using the standard Nvidia control panel. I was NOT able to hit that refresh rate using DVI or VGA without major screen corruption. I was curious to know if anyone had the same luck using DP.
Right now I'm keeping at 72Hz, but eventually I'm going to try and see just how high I can crank it up.
EDIT:
I forgot to mention, I confirmed that the monitor is, in fact, running at 72Hz using its control panel.
