I have an hpxw9300 workstation and the fan in the back (not the power supply) sounds like a damn train. It gets worse the hotter it is obviously. What can I do? Its a pretty big 4 pin fan
I was hoping to replace it with a quieter fan, not the same one. I think it is a temperature controlled fan. I think thats what the 4th pin is for, but I may be wrong. Can you recommend a 120mm quite fan?
