I recently purchased a HP P4515X for one of my clients. Unboxed it, plugged it in, set the network up and proceeded to install the universal print driver on the server 2008 x64 (the driver hp made me use)
The driver install went fine. I set up two versions of the printer. One version was set to always print to tray 2, the other was always set to print to tray 3. This is where the problem lies.
On the REALLY old 8100N I was able to go into driver settings (using the same universal print drivers) and tell the first instance of the printer that only tray 2 was letter paper, and trays 1 and 3 were Not Available. and the same for tray 3 on the second instance. These settings are not saving, period. I click apply, I see the settings stay, I click ok, and as soon as I go back in, every tray is set to letter again, and the printer always wants to pull from tray 3.
This is easily fixed by going into printer preferences and setting the tray you want that printer to always use. BUT the issue with that is, when I deploy the printer with group policy, the printer preferences don't deploy with it... The only solution HP has for me is to take their DDU program and prepackage drivers with the correct configurations for each printer, and push it out to all the computers, which is absolutely ridiculous. Then there is the AD addon which doesn't allow you to set trays and is very cumbersome to set anything else...
Does anyone know how to push the hp printer preferences out to the windows 7 x64 clients? OR make the hp universal printer driver let me use the device settings tab to save my tray settings?
