HP safe mode
Whimpy
Which F-key do I use to get out of safe mode, for this HP pos, not accepting the norm f-8, and I cannot remember which one it is.
DELETE I think try hitting tab as well and it may clear away the graphic so you can see the text.
Just restart.....That will put you back into normal mode......
F8 will get you in, reboot will get you out :)
You must be refering to geting past the POST logo?
If you give even some slight clues as to what you're trying to do and what model you're working on, I can help out. We don't have ESP on the forums though, so you have to specify the important info.
