HP s7210n problem ....
ClockerX
Hi, I have a HP s7210n Slimline . AHd it for about 2 years but recently it stays on for about 15 minutes, and then the monitor reads "no signal". The power LED stays on, so does the motherboards. I don't know if its the onboard (vga) graphics in the motherboard that loses the signal. Maybe its a motherboard malfunction? The powersupply is narrow and long, not the standard ATX Psu's and uses a small version of a 24-pin connector so i couldn't use the standard PSU to test it. Say it is a motherboard problem, would a microatx hole alignment fit, then again i would have to check if the lga 775 oem cpu fan would fit? The Hp motherboard uses a socket 479 mobile processor with a heatsink, the cpu fan is in a tray thats above the board. Anyway, any of you experts may have an idea with whats wrong? Let me know, thanks
Edit: also if i may add when the video signal is lost, the cd drive does not open, so its a psu problem?
