Mine comes right out just squeezing the sides together and pulling up.
How long is the internal SFF-8087 cable? Is there enough room to hook it up to a RAID card where the SFF-8087 connector is in the back of the machine?
I would be bringing the cable from the front of the machine to the back - where the SFF-8087 ports are on the LSI RAID Card I want to use (LSI 8708EM2). From what I can tell it should work. If it can fit on the P212 - which is exactly where the SFF-8087 connector is on the LSI 8708EM2 - I should have no problems.It is not terribly long... the connector is near the front of the case left side of mobo...
before you grab a raid card I would make sure you can disconnect it from the mobo... out of two microservers I was only able to get one 8087 to detach from the mobo...
the cable will require rerouting to make it long enough... but I have attached it to a SA P212 so it also depends on where it attaches to the card...
btw... I am an intern at hp...so if you have other server questions... I have lots of toys in the lab...
Just FYI: I have this server with 5 samsung F4EG 2T 4k HDDs, and FreeBSD 8.2 with zfs raidz1. the read speed is about 300M/s, write speed is 250M/s.
when create zpool , it need to do a trick to make 4k sector.
and from this posthttp://forums.overclockers.com.au/showthread.php?t=908337, raidz1 is better with 3/5 disks
How did you connect the 5th drive to the motherboard?
NoDoes it turn my BIOS into Russian language?
I added a HP P410 SmartArray Raid controller and one of those 5.25 4 x 2.5 drive bays in the space for the optical disk. All works fine for the 4 internal bays and the 4 new 2.5 inch disks.
But I've tried 2 different external esata boxes on the esata connector on the back of the server and in each case it sees only 1 of the 2 internal drives in these boxes even though the boxes are setup as one 4TB volume. Is this correct? Tried using Win2008R2 and WHS2011 RC.
By the way I get transfer rates from internal drives to esata drive of 90MB/s versus 25MB/s to the same boxes over USB....But USB sees the full volume of 4TB while esata does not.![]()
Great, thanks for the info, I was also looking at the P212, is the raid 5 option on the cache card or its like the other raid card, software bios activiate ?
The website says 256MB battery-backed write cache (BBWC) module for RAID 5, 5+0. but I wasn't 100% sure.. let me know, thanks..
All raid except for 6 will work without cache ... zmr mode... the cache can be forced on without battery... there is an advanced licence key that enables raid 6, stripe migration, and a few other trixy things that most people will never use... lol...
But in case you just love raid 5 i suggest using10
are there any issues if I were to install the included 160GB HDD onto the discrete SATA port?
I have already installed W7Ultimate and it is running just the way I want it, would the mobo still find the drive as a bootable drive? are there any changes that I would have to make?
Apparently the SATA port uses some SATA to PATA bridge(meaning it runs on a legacy IDE mode i guess??)...
anything with mini-sas should work... but as this is an amd raid solution on the motherboard and not a bl110 there is just sata on the backplane... no drive lights...
so another controller and cable should work... have fun routing.... it is tight.
Just install the x86 FreeNAS, not the AMD64 FreeNAS.hi all,
I am going to buy this microserver, but I have a question.
Someone that use FreeNAS has found a solution to use slimNAS (squeezebox server) to stream to a squeezebox duet?
here
http://www.herger.net/slim/detail.php?nr=1026
they say that do not run on the FreeNAS AMD64 Build
and the Proliant has an AMD64 Build, so how to use FreeNAS and stream to a squeezebox?
Thanks
Other topic. Yes you can add a 3.5" HD into the 5.25" ODD case. You need a 3.5" to 5.25" adapter and some small screws. Then a SATA-Data-Cable with a angle cable, and a P-ATA Power to SATA-Power convertor. Both is not included. If need could provide some pics.
Thanks, Pat
My question is I'd like to have the OS on the 250GB drive, a pair of RAID1 2TB drives, and then be able to move the 250GB drive with the OS into the ODD bay when I want to add another couple of 2TB RAID1 drives....... and have this box talk to my Win7 ultimate laptop... any ideas if this is do-able and how, please?
Anyone installed the latest Debian6 amd64 with Samba on this lovely little box? I am able to connected and browse thru the directories from my windows7 client. But each time I change the directory with the "back" button, the windows7 client freezes for about 1-2s. Also when issueing a mount, this takes about 30s until the windows7 client finds the share. Read a lot about performance troubles samba/win7. Any working smb.conf out there?
Any of you guys had improvement of performances by using dedicated pcie sata controller versus the motherboard one?
