HP P1230 Questions.
Hello everyone,
According to spacediver in this post, as well as research on my own, it seems like my HP P1230 is a rebranded Diamond Pro 2070SB (is this true?).
I was provided this extensive manual:
https://pdf.yt/d/IkP1h6fBnNX66lR8
If it is indeed the technically correct manual (is it?), are there any jewels to note that I could tweak on the CRT to better suit the game Quake Live?
Thanks for the replies!
try entering factory mode, as instructed in the manual, and see what happens.
as for quakelive, I recommend using a resolution that allows as high a refresh rate as possible.
According to the user manual, you should be able to get 160 hz @ 1024x768.
Make sure you turn off vsync, and set com_maxfps to 250 in quakelive. You'll be golden then.
Fancy finding you here spacediver! :D
Ok, but I don't know anything technical about monitors so would I be alright if I did things step-by-step or is it too risky?
I'm not sure if my computer can handle 250 fps but I can try.
Should I disable v-sync through the Nvidia Control Panel or just in-game?
Thanks for the confirmation.
Well, flood's post just nailed the confirmation, so no need to do that.
If your computer can't run 250 fps in quake live @ 1024x768 then you need to move past the dinosaur age :)
com_maxfps 250 and cg_drawfps 1 to confirm. turn off all the post processing stuff, and try r_picmip 5 or something.
Both. In game command is r_swapinterval 0
I meant changing settings and/or getting into the internals of the monitor.
Also, the manual says how to get into factory mode but doesn't explain what to do once there.
I have an Intel Core 2 Duo, 4 GB of RAM, and an Nvidia GeForce 9400M.
Is it a simple on/off switch or are there many things I have to switch off in the Nvidia Control Panel?
I only suggested u do that so if factory mode works, you can be sure it is the same monitor. Anyway, unless you're interested in color or geometry calibration, probably no need to go in there.
Give it a shot and see what happens.
try google :)
I followed the directions and I was able to enter factory mode. The only difference was that the manual had:
H2-OW-01
FACT DATA 0
While my HP P1230 had:
H2-HP-02
FACT DATA 0
So I guess this confirms it is the same monitor like you said.
There are some other things I am working on, but will do once I am ready.
try google :)
I guess. I'd rather be sure of what I am changing though. I'll look into it. Thanks. :)
I am running at 120 Hz now at 1024 x 768. If 160 Hz is supported at that resolution, why am I not seeing it listed?
