I'm looking at getting the MediaSmart EX 470.
I've read quite a few reviews and forum postings (on this site and others) and I think it's a pretty good fit for what I want. I have a couple of questions for anyone that has one.
When it comes to adding hard drives: Are there any pit falls with getting the same size or type of drives? I'll probably get the EX470 (500GB) version and immediately put in an additional drive. Probably a 750GB or 1TB. Is there anything wrong with having a 500GB and 1TB together? In the future I'll probably add anther drive also.
itunes Server: These seems like a very nice feature. And one that is going to prove to be very important for me. But, will it allow you to play protected media (such as items purchased from itunes)?
Are files on the MediaSmart server copies of files from each users PC or do they only exist on the server? Pictures, Videos, Music Files, Documents. Do they stay on the main users PC and on the Server or only on the Server?
My main reason for getting this Server is for backup purposes and to make things easier for my family (mostly my wife). I want her to be able to use the main work station in our house (running Vista) or her notebook (running XP) and have all the files appear to be in the same place and be very seamless. I want her to be able to edit or create a word document on the work station and be able to go back to that document later from the notebook and edit it some more with out her having to navigate to the work station through the server to get the document. I need to make sure there are not multiple version of files laying on each PC and the server. I assume it all depends on how it's set up, but I would like to make sure I can configure it like that.
Once I get things configured I would like to have the server holding all the files we use (music, photos, videos, documents). If copies of those files are still kept locally on each PC, I would like them to be automatically synced across all the PCs and the Server. Have all those files duplicated on two physical drives on the server. I have an older External USB Drive that I would like to hook up to the Server through the external USB and have the server store backups on that also. Yes it may be overkill, but as soon as I get it set up I won't have to interact with it and I'll be pretty well protected.
Sorry for the long one, but any feedback is appreciated.
