HP LP2475w Weird Problem
ZugZinct
Hi,
Great forum here. Lots of good info!
Maybe someone here has seen this before or maybe I'm just missing something.
I just replaced my old Samsung 19" LCD with a new HP LP2475W and I have a weird problem. I run WinXP SP3 with an ATI 4670 GPU hooked up thru DVI.
Here's the problem. Ever since upgrading the monitor, my machine won't go into System Standby IF the monitor is set to power off 1st. If the machine is set to JUST go into standby (without turning off the monitor 1st) the machine goes into standby just fine.
I have tested by swapping my old monitor back in and then the system powers down sequentially just fine (monitor powers down 1st then the system)
Can the new monitor actually cause this behaviour? DDC/CI has no effect
Thanks for any info.
