You can use HP Display Assistant to adjust brightness, contrast, colour and white point, then save these to presets which are then selectable from the program when you want to change between them.
i thought i read on hp's page display assistant is for connections other than digital?
The glow isn't so bad if you turn brightness way down to 10 to 20%. If you sit in front of it with your nose to the screen the background bleed will be worse, but so will be your eyes. Sit back a littleHi Again,
After waiting over a month since I've sent my LP2475w back, I finally got my money back, and I'm not sure whether I want to order the LP2475w again.
I really do like the monitor a lot, but the white glow effect is quite annoying, but then again other screens might have issues that are even worse than that.
I would order it again if I could be sure that it doesn't have any issues, my previous lp2475w had some serious green hue issues, and I don't want to send another one back.
So, what should I do?, I have several options:
1.Order the lp2475w again, and hope this one is without fault.
2.Wait until HP/LG Display get things right (hopefully), and order when the problems with the current batch are gone.
3.Find an alternative monitor (if any exists).
I'm not sure what to do, I really do want the HP, but with the quality control issues right now I'm not sure its worth risking ordering it again.
If anyone knows another 24-inch LCD monitor that is in the same price range, and is just as good it terms of picture quality, input lag etc, please let me know.
So, what would be the best thing to do right now?
The green hue can be adjusted out using the custom temperature. Get a calibration device if you want to be sure your colors are exactly as they should be (though only in color managed OSs and apps). The eye one display 2 is a great hardware calibration device and the software is nice. This screen isn't perfect but I think it's a good compromise as a whole.
There are no panels around this pricepoint that are comparable that I know of (and I've looked very hard). There's one from philips with the same panel that's a bit cheaper but also lack a lot of inputs/fearures.
i was just looking around the wed and found this man Stefan Didak that got four of these monitors on ergotron arms take a look
www.stefandidak.com/office
Nobody?
Hello all, did anybody have a trouble with banding in gradients after calibrating this LCD and loading the color profile to LUT? After calibrating I see banding in the tones of the sky on some of my photos. Is there any way or solution how to fix that?
Hi, I'm tihnking of getting one of these and wondered if the base/stand can be adjusted for height? If so, how? I had a look at one of these in a store but obviously couldnt start pulling and tugging at it. From what I could see the stand only adjusted for tilt and swivel.
What's the best place to purchase the LP2475W from? I was thinking Provantage, they have it listed for $575. But, I've never purchased anything from Provantage before.
Thanks!
I ordered mine straight from HP, figured if I had any problems, they would be best to deal with, it's their hardware.
http://h10010.www1.hp.com/wwpc/us/en/sm/WF05a/382087-382087-64283-72270-444767-3648442.html?jumpid=reg_R1002_USEN
I pushed the button on one yesterday £321.64 direct from HP inc. 4years next bus day support , VAT+ delivery![]()
If you look on youtube you can see that most of the videos are that of problem cases..
http://www.youtube.com/results?search_query=LP2475w&search_type=&aq=f
Is anyone else have problems with this model ?
Also since the sRGB preset is junk.. is a hardware calibrator necessary for this LCD to reproduce sRGB accurately ?
I am extremely interested in buying one of these as it looks like the best bang for buck out there in the 24" 1920x1200 market.
It cannot reproduce sRGB accurately, calibrator or not.is a hardware calibrator necessary for this LCD to reproduce sRGB accurately ?
$470?! How did you get that price?
i hope so, i currently have a Formac 2010 as my main screen and had a 19" Hitachi as my 2nd (mostly page layout) but it gave in after 12 years.. i now plan on having the HP as my main and moving the Formac to my 2ndCongrats, you'll like it, awesome monitor.
