HP LP2475 menu consultation
Odrackyir
Hi guys, is there a way I can make my HP LP2475 faster when it comes to identify and activate inputs? I mean, each time I switch on the monitor, it starts checking all the inputs, and takes up to 10-15 additional seconds for actually starting to display my PC via HDMI. I've tried messing with the menu and all that, but nothing happened. Is there a way to configurate it for displaying HDMI automatically?
Help!
Thanks!
Hi,
you can disable the automatic scan and just select it manually if you know you will i.e. always use the HDMI connection.
I think it was under management just disable both the auto functions - i did this the other day and now its faster other than that it could be firmware / Hw revision of the monitor if its the older one.
a5ian300zx
