Any users out there? How does this compare to the current crop of IPS offerings? They are fairly cheap refurbished, so I'm considering 3 monitor portrait configuration. However I have no way to evaluate them before purchase.
I hope you get some feedback..I have been looking at this panel also..A bit spendy new though...S-ips it claims...I'm a bit twitchy about all the uniformity problems I read about on the 23" e-ips LG panels most are using,NEC.Dell etc...I may go the the NEC PA231W,e-ips but with colorcomp,also more money,Bob
i've been using one (early IPS sample) for about 5-6 years. good monitor that calibrates well. backlight is not nearly as blindingly bright as modern prosumer panels, but is much more stable. keep in mind that there is a panel lottery (MVA) on later samples.
the AG has never bothered me, but iirc it did bother some.
