Hi Guys,
I'm helping HP to reproduce/resolve 'flickering wave' issue. Perhaps gathering more data will help them to resolve the issue.
To get the firmware and panel info do the following:
1. Turn off the monitor
2. Press and hold the leftmost menu button and push the power button
3. Release the power button.
4. Release the menu button and then press it again
5. The OSD menu will come up and the 5th item from the top will be previously hidden "Service..."
6. Select "Service..." to see the panel info.
To reproduce the problem do the following:
1. factory reset
2. lower brightness to 20 or lower
3. go to below URL and check grey background, if your monitor is faulty you should see rolling flickering wave. Starting around middle of the screen going down.
http://www.w3schools.com/css/tryit.a... tion_relative
Can you please post your revision,date of production, firmware and what region are you in (country or continent).
TIA
I start:
1) flickering happening , GSM002, Dec 2006, 114, Canada.
1. factory reset
TIA
I start:
