HP LaserJet 4+/m network installation
lost eden
I have a HP LJ 4+/m with JetDirect card & although I've been running it off parallel since I got it, it's by far time that I take advantage of the JetDirect card & the free port on my network switch.
I've tried searching HP's site & the rest of the web for manuals/guides etc. but can't find one that is remotely close to what I want.
I have 2x Windows 2000 Pro boxes, one of which runs a DHCP server, a Linux box & a Mac laptop, all connected together with a 5-port switch. Naturally I plug the printer in to the 5th port of the switch, but beyond that & I'm at a loss. Windows 2000 seems to print fine to the printer over parallel without the need for any drivers to be installed - does this mean that I don't need to install a driver for network printing, can I just change the port? It works with Linux to, so the same question applies there. Mac I have no idea - this Mac doesn't even have a parallel socket & I can't honestly believe that Apple would really be bothered supporting old hunking pieces of hardware, it would go against their image!
I know that a couple of people on these forums own or have owned these printers, so I'd really appreciate an idiot's guide crash source in how to get it set up on the network!
It's a pretty straight forward process, turn the printer on and hold the online button for about 30 seconds till it spits out a piece of paper with it's IP address on (or you can find it via your network if you prefer)
On each computer, go to Add Printer, select Printer connected via Network and you should be able to enter the IP address you found. You *might* need a driver, but I'm fairly sure the Laserjet 4 is at least one of the XP supported printers.
It's reporting 192.168.0.87 but if this is coming from DHCP, then isn't it possible that it might change on reboot?
EDIT: I was right, the IP address changes every time I turn the printer on - 192.168.0.87, 192.168.0.113, 192.168.0.43, etc. Do I have to give the printer a static address? Because surely that's risky if the DHCP server gives that same address to another NIC?
