- Feb 6, 2006
This was a dead laptop that I got from my neighbor for partial trade for a working one, and I've replaced the motherboard to bring it back to life again. But the old motherboard had this same problem before it died.
When the laptop goes into hibernation while it's plugged in with the battery in place and then unplugged (like I'm going to take it somewhere else), if I plug it back it back in before turning it on, it will not power up. The charge status light on the side won't even come on. I have to unplug it again, remove the battery, and plug it back in before it'll power up again. Then I can put the battery back in and it'll work just fine.
If I turn it on before I plug it back in, or just don't unplug it, it'll power on just fine. Also, if the battery is left out of it, it works ok.
Any ideas on what might be causing this or how to fix it?
