Mr. Pedantic
- Sep 19, 2009
Got this printer about 4 months ago, installed it on my previous Windows 7 Home Premium 64-bit installation, worked perfectly.
I just did a reformat/reinstall, but now the printer and its driver won't work together somehow. When I plug the printer in, Windows makes that sound that you get when it recognizes new hardware, and I get the dialog box that says it's installing the driver, but when I look under Devices and Printers The F4400 is classified as 'Unspecified', even after I install the driver that came with the printer.
When I go through Windows troubleshooting, I get something like this:
Advice?
When I click 'Apply this fix' I get:Reinstall Device Driver
There is a problem with the driver for USB Composite device. Reinstalling the driver might fix this problem
--> Apply this fix
--> Skip this fix
Continue troubleshooting without applying this fix
The printer is turned on and plugged in, by the way. I unplugged/replugged it, turned it off/on, switched ports, uninstalled/reinstalled the driver, and nothing seems to work.Problems found
USB Composite Device has a driver Problem Not fixed
Advice?
