HP EX475 esata expansion?
zer0gravity
My roomate just got an HP EX475 and he put 4 x 1TBWD drives in it and already filled it. (porn I can only assume) I noticed it has an esata port and knew that it could possibly support or control another span of drives. Could i buy a break-out cable or does this port support port multipliers or something?
Anyone know?
Looking into adding so more drives so would this be able to be added to the esata on the HP?
http://www.newegg.com/Product/Product.aspx?Item=N82E16816132029
The 47x and 49x series can properly handle the e-sata port multiplier and the 48x series does not.
I think you can add an additional 4 bay unit on the 47x and 5 bays on the 49x, though I only have firsthand experience with the latter.
I picked up a Sans Digital 5 bay unit for ~$120.
Thanks! I think i'll just order it and see if it works....if not I can always reuse it somewhere
