Hi, I recently bought a HP ENVY 17t-j100 Leap Motion Laptop, aside from some of the issues I have it, the salient issue I'm hoping to find out here is what type of panel I'm using here and if anyone can tell me what I'm seeing. The panel PnP ID is: LGD03FB -- it's a LG AG panel but can find no info on it anywhere. The problem I have with it is that everything except for black / white shows a thin white grid, like your seeing everything through a white grid. On my other desktop displays and laptop displays, if you look close enough, I can see a black matrix grid (esp. on my 55" TV -- but that's if you look up close, which you don't for the TV,) but with this laptop I can easily see at a distance on 24 inches away the white grid which makes everything look like the display was put together with tiny squares with white edges. The viewing angles seem to be good (except viewing from the extreme bottom which I wouldn't normally do anyway, so I don't care about that) and color is good to very good. It's just the grid that so awful. With this info, can you tell if it's a TN or VA panel?
Thanks in advance!
MonInfo below:
Monitor
Windows description...... Generic PnP Monitor
Manufacturer............. LG Display
Plug and Play ID......... LGD03FB
Serial number............ n/a
Manufacture date......... 2013, ISO week 0
Filter driver............ None
EDID revision............ 1.4
Input signal type........ Digital
Color bit depth.......... 6 bits per primary color
Color encoding formats... RGB 4:4:4
Screen size.............. 380 x 210 mm (17.1 in)
Power management......... Not supported
Extension blocs.......... None
DDC/CI................... n/a
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.640 - Ry 0.335
Green chromaticity....... Gx 0.320 - Gy 0.630
Blue chromaticity........ Bx 0.150 - By 0.060
White point (default).... Wx 0.313 - Wy 0.329
Additional descriptors... None
Timing characteristics
Range limits............. Not available
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 139.000 1920 1968 2000 2080 1080 1083 1088 1113 -hsync -vsync
Detailed timing #1....... 1920x1080p at 40Hz (16:9)
Modeline............... "1920x1080" 92.670 1920 1968 2000 2080 1080 1083 1088 1113 -hsync -vsync
Thanks in advance!
MonInfo below:
Monitor
