I decided to start a new thread because this has now gone from a request for build suggestions to build troubleshooting.
To summarize my situation for new readers and to remind old readers I am upgrading a HP Blackbird 002 Dedication edition computer. Since it is my first ever build, I decided to do it in steps. I kept my 2 NVIDIA Geforce 8800 Ultras for now. Since I live in Chicago and I wanted to finally get started I went to Microcenter and bought everything there. Luckily they had GREAT prices! Here is what I started with.
$310 - Core i5-2500k and MSI P67A-GD65
$50 - Patriot Extreme Performance Sector 5 G Series 8GB DDR3-1333 (PC3-10666) Enhanced Latency Dual Channel Desktop Memory Kit (Two 4GB Memory Modules)
(no G.SKILL in stock and the tech guy highly recommended this so I gave it a shot)
$50 1 TB Toshiba HD (until my SSD arrives)
$88 - Windows 7 Home Premium 64-bit (open box/resealed)
For now I decided not to water cool the CPU so I just used the CPU fan it came with. The MB was VERY different from my ASUS Striker Supreme 680i, but I think I hooked up everything correctly. When it came time to connect my 2 DVD drives I was shocked that there was no IDE slot! Rather than swap out my cool slimline DVD drives I decided to drive back to Microcenter and buy a PCI to IDE card (hope that was a decent decision)
I closed everything up, powered up, and things worked! Got to the BIOS screen and looked around, then chose to load the optimial settings (as recommended in the manual) and booted off the Windows 7 CD. Here is were things went bad.
The Win7 install stopped with this error:
"A required CD/DVD device driver is missing. If you have a driver floppy disk, CD, DVDm or USB flash drive, please insert it now. Note. If the windows installation media is in the drive, you can safely remove it for this step."
I tried using the CD that came with the PCI to IDE card but that didn't work. Looking online with my laptop I saw people claim that perhaps the DVD drives were too old, or their firmware needed to be updated. Since I knew those DVD drives worked with Vista I tried installing Vista but I got the same error.
By now I was extremely frustrated (and cursing Microsoft) and frustration leads to dumb impulses. I decided to put my old Vista OS HD in and try booting off of that. I figured with such a changed PC that Vista would not recognize it and give me some sort of error. To my UTTER amazement it worked! Not only that but it sensed all the new hardware and installed drivers for it all!
So, it looks like my hardware is installed correctly, but how do I install Win7 on my new drive? The only solution I read was to install off of a USB drive. Any other suggestions?
Thanks!
Thanks!
