HP 2335 DVI cable issue (Maybe HDCP issue)
JLove
I just set up my new system. All of the following parts have been tested and proven to be working fine independent of one another. When I try to use them together, all h_ll breaks loose.
ATI Radeon HD 2600
DVI Cable
HP 2335 23 inch monitor
I want to connect through DVI but I just get a blank screen as if no cable is connected. When I connect through analog, the monitor works. When I switch to DVI, no signal is detected. All connections and settings are set properly.
Monitor works fine with my old system though the DVI connection. DVI cable works fine. Why can't I just connect the new card to the monitor through the DVI input? I have read about HDCP compliance. Could this be the reason I can't use DVI? Is there a work around? Is there a noticable difference? A new monitor is not in the budget. Thanks.
JLove
It's not a problem with HDCP. That only kicks in when you're watching blu-ray or hd dvd
The card works fine with DVI...just not when connected to my monitor HP 2335
Traded in the card for a 8800 GTS 320mb. Works fine through DVI with my monitor. Wierd. Love the new card BTW.
