darkunitzero
- Jan 26, 2007
after doing this i received a ffmpegsource: couldn't open e:\blah\blah\blah\video.mkv
This thread is old and I do not support this method any longer.
When we made this, it was really the only option.
I always use AnyDVD to rip to Folders, and then to MakeMKV.
However I have not tried this method with HD-DVD's, I know it works for BluRays.
NOTE: This method will not produce HD quality Audio....it will downmix everything to 5.1.
If you want 7.1 HD Audio you must manually demux select streams, and remux them together.
@SirKronan
Right now the only thing that I know that will work for sure is to get:
Eac3to
HdBrExtractGui(notsure on spelling) - its a front end for Eac3to
MKVToolNix
eac3to/hdbrextragui - this will let you extrac the streams you need. I always choose video with output set to MKV, and Audio I extract to 8 channel FLAC....but you can choose whatever you like.
Then open up MKVMerge...mmg.exe inside the mkvtoolnix folder, and you imput the two files you just extracted into this and it will mux them together.
Okay, I'm trying to do what you say, but I have no idea how. Do I put the ISOs in the eac3to directory? This seems out of my league ...
I've extracted the ISO's successfully with AnyDVD HD. I haven't mounted them yet, but assuming I can mount them with Daemon or something, do I have to do that in order to use the programs you listed above? There's gotta be a better way to do all this. All I want to do is legally backup my movies. I mean, it's not like the discs will last forever. Once I go blu ray I'm sure it will work just fine as there are plenty out there with blu-rays now. Thanks for the help so far.
You can use anydvd hd to rip to hard drive, then tsmuxer to join the features into a single file, then use ripbot to shrink the file. The first two steps take about a half hour. Ripbot can take up to 12hrs even with a quad core and 4gb ram depending on the settings.
wow.. this process looks involved.. but I want to get all of my HD DVDs ripped and moved to my drobo for use on WD TV... looks like I have some work ahead of me. Is there any updated consolidated version? I can live with downmixed 5.1 audio.. just used AnyDVD HD with makeMKV? or Ripbot? 12 hours to rip.. whew.
By the way,i want to burn my mkv files to dvd.I have tried WinAVI and ConverXtoDVD before,any other better program can do a favor for me without a loss of quality.Thank in advance.
you're trying to convert the single .MKV file to a DVD structure for playback on a non-computer DVD player, is that right?
