How's your G7 holding up?
ballpoint
My G7 is holding up brilliantly after a year of hardcore usage. I start every workday by windexing my mousing area as I don't use a mousepad, then I polish the feet a bit. The battery lasts a day or two but I have come to actually enjoy swapping it out. I've taped down the charger\RF dock so that it won't move when I slap the dead battery in.
lovin my g7, had it since christmas, doin well. battery lasts a for a day maybe a day and a half if the im not suing it much. mine has good range 2. the feet are startin to wear out tho =(
Works as good as the day I bought it (I've had it close to a year now). The plastic on the top right mouse button has a little bit of wear on it where my middle finger rests though. I'm glad I bought it, it has all the advantages of a corded mouse with none of the disadvantages.
The skates still slide pretty well, but they've got a little scratched up from running over the occasional crum of food or dirt that finds its way onto my mousepad and from using it at my friend's house on his flawed table. They still have a while to go before they need a replacement.
I have had mine since the day it came out. Still works great...
I've had mine roughly a year and love it, but I had to change the feet. It's getting worn out but still working properly.
my silver G7 died on me... well it still works but intermitantly it will just freeze and then it resets the dbi and then works again. really annoying while playing FPS
i think i will be buying one of the carbon ones soon....
need to change my battery daily, somehow the lifetime seems to have dropped but has plateaued at about a day's worth (7-8 hours).
other than that the mouse is tip top. i just dont like how logitech mice collect the grime off your fingers so easily. i need to wash my hands at least once an hour to keep my mouse clean.
Yea I want to say I change the batter every day or so but it is no big deal. Would have rather had a changing station where I just dropped the mouse into a dock though. Overall I'm still happy with mine though. Have had it since they came out.
I've had mine for about 8 to 9 months now, and it's starting to do that "freeze on you every once in a while" thing. Sometimes it doesn't do it at all, sometimes it's frozen more than it's not. The strange thing is, even when it's freezing on and off really bad, if I load up Titans Quest (only game I've been playing lately), I run into no problems...and it even seems to work better after I close it down.
Out of curiosity, anybody know why the G7 does this in the first place? Any fix?
