Hey, I am looking at an Ultra X-finity 500w PSU for a good price and am wondering how it will handle my system. You'll have to convince me pretty good, as I have been using much inferior PSUs with absolutely no problems.
http://ultraproducts.com/product_details.php?cPath=60&pPath=383&productID=383
My system:
Opty 165 at 2.85 or higher (dont know if I want to increase volts at all
DFI Ultra-D
x1800xt pe
RAID 0 Raptors 74gb
160gb Seagate
MCP350 WC Pump
Fan Controller with 3 120mm fans
I have used a $25 HEC 580w PSU and am currently using a OCZ Modstream 520w with absolutely no problems. What I really like about the Ultra, is the higher 12v rail and the cables. My modstream is just a bit short.
What do you guys think...
Feel free to recommend something else as long as... I CAN BUY IT FOR AROUND WHAT I SELL THE MODSTREAM FOR!!!
No offence, but a lot of times you guys recommend an upgrade that is just out of my budget...
THANKS!
My system:
DFI Ultra-D
x1800xt pe
RAID 0 Raptors 74gb
160gb Seagate
MCP350 WC Pump
THANKS!
